Originally posted by: jinduy
i have an amplified power antenna and it needs a power adapter to work properly...will anything get burnt out or become damaged if i plug in a 19v adapter? The antenna is supposed to take in only 12v.
Originally posted by: Eli
+7 volts over spec is a lot, you will damage something.
i take it this is for in your car?
Originally posted by: Stojakapimp
just go to radio shack or something and look for a voltage regulator that will drop 19 volts to 12 volts
Originally posted by: 0roo0roo
universal ac adaptors cost about 10 dollars😛
Correct, the amperage is usually so minisule that they cannot run anything. A good electronics supply place will sell 12V DC power supplies in the $20-$40 range that will provide all the power you need.Originally posted by: MercenaryForHire
And usually never pump out enough mA to power anything stronger than a Walkman. 😛
- M4H
That is very typical for an adapter like that, but I think usually you can get them a bit cheaper than $14+. That adapter has 300 ma * 12 V = 3.6 W maximum. 3.6 watts of power just doesn't power much of anything. And that is assuming their maximum of 300 mA is at 12 V and not one of its lower voltage settings.Originally posted by: 0roo0roo
the one i have 300mha not enough?
