- Apr 10, 2001
- 48,775
- 3
- 81
I have continually been reading comments in the Ford GT thread about corvettes such as
I must admit, I jumped on the bandwagon myself, without knowing WTF I was talking about. I have recently been watching the SPEED CHANNEL, and have come to realize that Corvettes can indeed excel well in the true TEST that is LeMans, even winning it.
It would seem obvious then that the LeMans corvete must be heavily modified from the comments I've heard here. If anything, the shape is quite different.
Basically, why is the corvette bad at corvnering?
Numbers/Statistics/experinces only please.
Usually problems with cars occur because of:
-Inferior/unmatched suspension that does away with body roll.
-Bad tires
-Weak brakes
-Bad center of Gravity.
-Bad weight ratio--appearantly the 911's specific placement in the rear makes the car rear-heavy, and causes "hopping" when @ full throttle from a standstill.
-Bad aerodynamics
-Big engine mismatched with uncapable or unsuitable chassis(Too much/Too little power...Too much/Too little Weight)
Beats the sh!t out of it?!?! Only in a straight line, throw twisties into it and your corvette isn't worth SH!T!
-Bad tires
-Weak brakes
-Bad aerodynamics
