- Dec 17, 2001
- 1,135
- 0
- 0
first off the case in mind is the sx830 which i will get soon
it comes with 2 rear 80mm fans in the back.
my question is that i heard that it is a good idea to put a case fan right across the hsf and that will lower your temp
but say that the 2 rear fans are 34 cfm and the case fan on the left panel is 42 wont all the air being sucked in get sucked right out??
Or should i move it lower and to the right more since its being sucked from upper left
here the best way to put a case fan to lower cpu temp?
Edit: I want to use the 92mm 42cfm fan casue i already have it so i want to make it use full
