I have a question about In-Win IW-S500 mid-tower ATX computer case/enclosure. When i look at the back view it doesnt have a small square for the 2 usb ports, I ordered a epox 8kta+
So whats the deal, am i gonna have to cut this..?
I have an S500 and the usb ports are on the plate next to the mouse/keyboard connectors but I did have to press them out of the template. You might check the place you purchased it from and see if they can supply you with the correct one. Would have thought that it would have been standard.
By the way it has been a very good case. Only down side was the PS which is very good but I went to a RAID setup so I went ahead and got another case with a 300.
