Originally posted by: Spac3d
Define bad.
Originally posted by: Ylen13
My red line starts at 6.5 if i let go of the gas when it get to 6.4 is that bad for the engine?
Originally posted by: Trinitron
It is not a good idea to run the car into the red section of your tach ( or to red line it) on a regular basis. Once in while won't hurt but the engine was not designed to run in that power range. in 99% of cars on the road, NO POWER is being made at the red line anyway, and redlining the engine will not make it go faster. Most street cars have a power band of about 1000-3000 rpm where they make their torque and 2000-6000 where they make their horsepower.
Ummm...no. Why would it?
i don't know that is why i ask. Someone told me if you rpm close to the red line its bad
Wait, now I get it. You're asking if it's bad to run your car at those RPMs, even if you're only there for a second since you let off the gas right before redline.
Don't know, I take my car past 5000 rpm (redline is 6000, 1995 Geo Prizm) somewhat frequently. I figure if the engine wasn't meant to go that high they would've put redline (where fuel cutoff begins) lower.
Edit: My car makes peak horsepower at 5500 RPM too.
You will put allot of wear on the car by redlining it frequently. You could reduce the life of your engine by half or more. You could through a rod, blow a head gasket, and in some cases with front wheel drive cars I have seen the half shafts COME OUT of the differential... that is BAD.
What kind of crack are you smoking today? Must be the real good kind.Originally posted by: Trinitron
It is not a good idea to run the car into the red section of your tach ( or to red line it) on a regular basis. Once in while won't hurt but the engine was not designed to run in that power range. in 99% of cars on the road, NO POWER is being made at the red line anyway, and redlining the engine will not make it go faster. Most street cars have a power band of about 1000-3000 rpm where they make their torque and 2000-6000 where they make their horsepower. Anything above this USUALLY shows an immediate decline in the power band...
No offense, of course.![]()
The proof is from the auto maker... thats why that sections of the Tach is in RED... read your cars owners manual and it will most likely tell you not to rev the car to red line... most manuals TELL YOU what rpm to shift at, there is a shift light that comes on.
This is really common knowledge when it comes to cars, if you need any more proof call an auto shop and ask them.
Because its your car and they aren't going to tell you how to drive it. Most cars do have rev limiters now days to keep you from grenading the motor... but redlining constantly is not any better and you get no power from it. The sooner you wreck your motor by driving it hard the sooner you have to buy a new one... another reason to think why they let you go that high in the rpm band.The section of the tach that is RED is the section that is after the REDLINE. I don't go up in that area, I can't because of the fuel cutoff. So if it were bad for the car to run at that RPM, why would the automaker let you?
That's barely true. In my car the power peak is at 5500 RPM and redline is at 6000.
