Question about cable wraps...
Fallen Kell
Ok here is my question. What size (width) cable wraps are needed to go over 4 pin power supply? I was looking on svc and there are a few different sizes ( 1/4 inch, 1/2 inch, and 3/8 inch). What I am looking at is the FLEXO Chrome Sleeving for use on my Antec TruePower cables (all of them basically). Any ideas on what sizes I should use? I am sure someone in here has done this before...
There's 2 connector's on the TruePower I couldn't sleeve, both to the mobo. The 1/2" sleeving and/or heatshrink won't fit over those two, and I'm not going to try and remove the pins from them (no proper tools). Other's look great when you get through though. I used Red heatshrink to match what TruePower has already. Have fun with it!
just another cheap suggestion...
you could always use wire loom too. you know the stuff that wraps al those wires and tubes underneath your car hood. it's cheap as hell and available at you local auto parts discount store. made my case look hella clean (except that damn bastard wire running to my radeon 9700, which i haven't wrapped in loom yet) it too comes in different diameters
