- Feb 18, 2005
- 2,718
- 1
- 0
I have a 32" Sharp LCD TV and am connecting it to my machine via the DVI output from the 7800GTX to the LCD TV.
The problem is that the TV has composite, component, DSUB, S-Video, and HDMI inputs. I currently have a 25 ft DVI cable, and I need to know if I should go buy a DVI to HDMI cable, or if I can simply get a DVI to DSUB adapter to utilize my current DVI cable.
Quality wise, what would be the difference between DVI to HDMI, and DVI to DSUB for what I am doing? Would simply using the S-video cable be better quality than DVI to DSUB? I really don't want to go buy another cable at this point, especially since it needs to be 22 feet long, and a 25ft DVI to HDMI cable is pretty expensive.
Video guru's, I summon your knowledge!
