My oldsmobile (automatic) has a transmission filter.Originally posted by: LS20
no filters.. and false
This is highly debatable and there is no solid 'proof' either way, sorta like does synthetic oil make your engine 'last longer'. Actually I take that back, there is a lot evidence that synthetic oil does not make your engine 'last longer' and no evidence that it does except for manufacturer marketing and anecdotal evidence.is it true that if you have never changed the ATF and you have high miles, that should just leave it alone otherwise if you try changing it, it'll harm the tranny?
Uh......Originally posted by: tcsenter
Most transmissions have a filter of some type, even if only a screen. It is advisable to replace it every time you change the fluid, but that is only required about every 50,000~100,000 miles. Some manufacturers claim it should never be required.This is highly debatable and there is no solid 'proof' either way, sorta like does synthetic oil make your engine 'last longer'. Actually I take that back, there is a lot evidence that synthetic oil does not make your engine 'last longer' and no evidence that it does except for manufacturer marketing and anecdotal evidence.is it true that if you have never changed the ATF and you have high miles, that should just leave it alone otherwise if you try changing it, it'll harm the tranny?
The idea is not that it will 'harm' the transmission, but will cause an already failing transmission to become symptomatic sooner and thus require rebuilding/overhauling sooner.
Originally posted by: iamwiz82
every automatic transmission i have seen has had a filter. Not changing your fluid on a high mileage transmission is false. They recommend you do not FLUSH your high mileage tranny, however.
What about a high mileage toilet? Still no flushing?
what's the difference between a flush and a change?
stick your head in and try
Pretty much.Originally posted by: iamwiz82
a power flush is when they put a high pressure pump to pump out all the old fluid and then it is replaced by new fluid. The problem is that it tends to knock debris from places where it had accumulated to more damaging spots, like the valve body.
Why has there never been a single independent (non-oil company funded/sponsored) study which has found that engines "last longer" using synthetic oil? Not a single one. A four-ball wear test is not an "engine".What evidence is there that synthetic oil doesen't make your engine last longer? It is not anecdotal, it's a fact, all else being equal. All you have to do is look at the specs of the different oils.
Yeah right, peddle it somewhere else. This former Amsoil dealer isn't buying.Use whatever oil you want. If you get an AMSOil Bypass oil filter, your car will fall apart around your engine.
Consumer Reports, however, took several dozen remanufactured engines, disassembled them, measured and documented all critical moving parts using a micrometer, reassembled them, installed them in taxi cabs, then used a particular brand/weight of oil in each engine; ranging from the cheapest 'white label' conventional oil to Mobil 1. It reserved some of the engines to test different drainage intervals; ranging from the 'popular' 3,000 mile to over 6,000 miles. They disassembled each engine at 50,000 mile intervals and micrometered the critical moving parts again, then documented the delta.
Absolutely no difference whatsoever found between conventional and synthetic oils. Engines did not "last longer", nor did they have measurably "less wear".
Ok, your turn. I will not be holding my breath waiting for this non-manufacturer funded/sponsored study because none exist.Yeah right, peddle it somewhere else. This former Amsoil dealer isn't buying.Use whatever oil you want. If you get an AMSOil Bypass oil filter, your car will fall apart around your engine.
So true, and if we were discussing what's best for diesel engines based in Alaska or Northern Minnesota in January, I'd recommend synthetic all the way.taxis idle all day, which means that their oil is always at operating temp, therefore protecting the best. Synthetics outperform dino in the most important area - cold flow. Synthetic will flow much faster on startup than dino will, thus protecting more for the average user, as the most damage is done on startup. This is not an issue for a car that is running all day and rarely has cold starts.
The block heaters we used in our fleet at a major regional auto parts distribution center heated the coolant and oil.Some people don't have outlets for block heaters in their GASOLINE engines and as far as i know, block heaters only heat the coolant, unless you have an oil heater. Sure, some heat will make its way to the oil but not enough to make a difference.
True, in weather approaching or exceeding freezing temperatures, synthetic can 'outflow' conventional. In temperature/environmental extremes, synthetic can help keep engine temperatures a few degrees lower.Also with more and more engines being an overhead cam design, getting oil to the top of the engine is very important, which, again, synthetic will outperform any dino oil. I know i hated every cold winter day when i had to start my poor 4.6, because i had a bottle of 5w30 outside and the stuff would barely move when i turned it upside down.
And yet not a single study has proven this translates into "longer lasting engines" or "reduced engine wear". Not one.For someone who wants the best protection for their engine, synthetic is the way to go, no if's and's or but's. This isn't to say that dino is horrible and everyone should use synthetic, because many people do not drive in circumstances that warrant it's use, but syn. is better.
Oh its certainly possible to test. What is proving difficult (or nearly impossible) is to measure a benefit.the fact that it flows faster at startup, and that most wear occurs on startup, means that synthetic will protect and engine better than dino given the same circumstances. The problem is, there are other variables. Preventetive maintainence by the owner, oil change intervals, quality of oil filter etc. all play a factor, so it's not possible to test.
Ok, so you agree that synthetic is a waste in fleets, which is a big area that synthetic marketers target and claim to be seeing a benefit.When using fleet vehicles such as police and taxis, because they are not driven like normal vehicles they can not be used as a judgement on how the product will perform for the average consumer.
Its certainly possible to take a number of engines, have them remanufactured to 'balanced and blueprinted' specifications, all moving interfaces micrometered exactingly, then each engine installed in a car and driven in a way which reflects 'typical use', all maintenance performed at planned intervals (within an acceptable margin), then each engine disassembled at planned intervals (within an acceptable margin), including periodic oil analysis to measure all characteristics of the oil (including metal wear), remicrometer all critical parts and inspect all interfacing surfaces.
This is impossible? Why?
How can that be since you've just agreed that synthetics are a waste in fleets?
Originally posted by: toph99
Some people don't have outlets for block heaters in their GASOLINE enginesand as far as i know, block heaters only heat the coolant, unless you have an oil heater. Sure, some heat will make its way to the oil but not enough to make a difference.
12,000 miles on an oil change? That's 2 dino oil changes at the 5k intervals recommended today.....no savings there. If you change it every 3k, there's still no significant savings. You still have to change the filter for the synthetic to be effective, so you really save nothing at all.With a filter change and an oil analysis, it is possible to go upwards of 12 000 miles between oil changes, which can mean a lot of extra money for fleets. Dino oil will protect just as well in a fleet vehicle as synthetic will, just it has to be changed more often on average.
All the trans flush machines I've seen simply use the pressure from the transmission's own pump to first circulate some cleaner in the old fluid, then replace the old with new.Originally posted by: iamwiz82
