Question about Antec 3700SLK compatibilty issues
jerlebird
Hello all,
Has anyone here used this case in conjunction with an Asus A7N8X Deluxe mobo? I seriously like the potential of this case, but a couple of reviewers on Newegg indicated they had some problems getting that particular mobo installed (mounting points not lining up, etc.), resulting in some "hacking" just to get it installed. I also heard a couple of rumours that certain 5.25" drives are a tight fit, too.
I hope this is not the norm, since I really like the idea of that size case with 2 - 120mm fans and the 350 watt PSU.
Anyone had experience with this range of issues?
THANKS!
-Jerlebird
I have one. The case isnt bad, but it doesnt have a removable Mobo tray which is important. The ventilation of the case is kind of poor. You may just have to cut out the stamped grills.
Thanks carmat4...
Just looking to see what people's relative experiences are. I haven't dropped the $$$ for it yet. Still not sure.
