I am curious about what exactly controls the AGP and PCI divisors in current motherboards. I have always been under the impression that the clock generator controls these frequencies, and the bios enables the different ratios that the clock gen supports. I have been in a debate about the new KT266A based motherboard, the 8KHA+. I have this board, and I was excited to see that the clock generator used supported the correct divisors to keep the AGP and PCI speeds in spec @ FSB speeds of 100, 133, 166, and 200mhz. The clock generator chip in question is the ICS 94228. If you check this .pdf file for the 94228 clock gen and look at the table on page #6, it clearly shows the AGP and PCI speeds in spec @ 166mhz FSB and 200mhz FSB. Now, as of yet, these divisors are not supported in the bios as going up to 166mhz FSB, the PCI speed does not fall back down to 33mhz. I was under the impression that if Epox enabled support for this in a future bios, it would be possible to run @ 166mhz and even 200mhz FSB speeds while keeping the AGP and PCI speeds in spec. A recent email reply from a Epox engineer claims that while the clock generator does support the divisors, the KT266A chipset itself does not? Is this true? I thought the chipset was independant of the AGP and PCI divisors, and that this was handled solely by the clock generator and the bios? Could someone explain to me what actually determines the AGP and PCI speeds and if the chipset itself also needs to support the dividers. Thanks in advance...
