Question about acids and bases
Status
Not open for further replies.
BigToque
11,700
I have had a little bit of difficulty understanding the concept of acids and bases in chemistry.
A molecule that is really stable after it has been deprotenated is considered to be a strong acid. If a molecule is a strong acid, does that mean that it is also a weak base?
I'm studying mechanisms and the concept of nucleophilicity and basicity came up.
As am example, H-Cl is a strong acid that breaks up into H+ and Cl-. Is Cl- considered a weak base because in Cl- form it has a full valence shell and just couldn't care about stealing another electron and deprotinating another molecule?
Ika
14,264
Yes, the Cl- ion is a VERY weak base (i.e. it sucks as a base, i.e. proton acceptor). All acids and bases are in equilibrium with their alternate forms (e.g. NH3 is a base, NH4+ is an acid). Acidity/basicity is a scale, if something is more acidic it is less basic. To remember this, think of the pH scale, with water at the middle. Water can both accept protons (H3O+, or sometimes just written as aqueous H+) or lose them (OH-, hydroxide). Pure water has a pH of 7.0, and the scale goes from 0-14, so it sits right in the middle.
BigToque
11,700
Thanks. I don't know why, but this is something I would say I knew, but this was definitely an "AH HA! I get it!" moment.
I'm starting to find chemistry really interesting now that certain concepts which seemed completely unrelated at first, are all starting to come together.
Moonbeam
74,800
6,775
You're forming a chemical bond, perhaps.
Status
