Spike
I recently assembled a A64 skt754 3400+ system for a friend of mine. This was the first A64 system I have put together (My barton 3200+ is still going strong) so bear with me. We just got the cheap combo from bzboyz listed here.
The system seems to be running stable but the temps are way outta control. His mobo was reporting temps of ~58 - 60 idle. He opened the side of his crappy case and the idle temps dropped to 54 but that is still too high. When he plays games he gets to 65 or higher. The HSF being used is the stock cooler master that came with the combo and we did not use any different thermal paste. The HSF came with thermal paste on the bottom as opposed to a thermal pad so I figured this would be fine. He was in a hurry so the 1-2 degree's saved by putting on AS 5 was deemed unneccesary.
My questions are these: How accurate are gigabyte motherboards known to be with there temp sensors? If those temps are accurate, how do you see a way to improve them? I am fairly certain I put the HSF on correcty but this was my first A64 setup so I have never used that black hsf bracket before. It feels snug so I don't think it is do to an incorrect fit.
As I have had him spend alot of money all-ready (he bought the combo, Antec SP 350, win xp pro, and a new cooler for his 9600 pro) so I would like to stick with what we have. I plan to help him mod his case to install a 120mm intake, probably a Yate Loon or one of my extra antec tri-cool fans so that should help that air flow problem. Anyone have any ideas what could be up? Something I missed? Thanks!
-spike
-spike
