Question about a hub?
datdamkid
I was wondering, could i share an internet connect w/a hub. Just having 1 network card in each computer. I don't remmber if I could I know I did this some how back in the day. But then I got my router..I'm just trying to set up something basic for a friend of mine...who doesn't have money....
Originally posted by: shimsham
yea, but he may need a seperate ip for each box, depending on his provider.
How could you do this? Could you please explain to me. And what do yo mean by seperate IPs?
With a standard DSL connection....only if one of the computers has Internet Connection Sharing. That computer would always have to be on for either of them to have Internet connection.
Where would i plug the Cable into? i know the hub only has places for computers....I don't know how you could do such a thing w/out having 2 NICS..
i strongly suggesty getting a router, you can really get them cheap- as cheap as a hub practically. cehck out ebay or even rebate thread. you could probaqbly get a 4 port router for under 20 bucks.
in that way you don' t have to worry about internet sharing and all that crap.
Power cable goes into the power outlets in the wall. Then you flip the On switch on.
Oh, btw, hubs don't come with 2 NICS. 😉 That's why you can't "do such a thing".
/-->Comp1
wall--->DSL modem-->HUB---
\-->Comp2
edit: ya my diagram didn't work out too well. Just buy a router with a built in 4 port switch, you'll be much happier and it'll be much easier. A router will cost about hte price of one or two months of DSL service.
This should go to the network forum. For a hub, you need multiple IPs. If you only have one, you need a router.
You cant do it. You need 2 NICs in one computer, and set up Internet Connection Sharing in Windows.
Hell, you dont even need a hub, just a crossover cable.
ok i get what you mean. you already have a hub. the only thing i can think of is this:
- 2 NIC's on PC 1. plug your internet into NIC 1.
- Cable from NIC 2 to HUB UPLINK PORT
- cable from hub into PC 2.
you'll have to manually assign an IP to each of the comptuers on the hub, including a manual IP for NIC2 on PC1 (NIC1 that is connected to your internet will receive an IP automatically).
So now, you need to enable sharing for internet connection for NIC 1 on PC1, and you'll have an IP address.
in PC2, set up a internet connection and specify that you are going through another computer or residential gateway, and specify the IP address of NIC2 on PC1.
make sense?
