- Sep 15, 2003
- 328
- 0
- 0
So far:
Danger Den TDX
Danger Den D5
Coolingworks Coolrad w/stock silent Antec fan (going to be upgraded soon)
<3 Tygon tubing
CPU is a P4 Prescott s478 overclocked from 2.8GHz to 3.6GHz @ 1.41v
I bought some green UV dye from FrozenCPU and a 80CFM fan to stick on the back, controlled by the mobo. So far it seems like it will be a kick-ass setup.
I can get to 3.8GHz stable, and I can POST at 4GHz. So close! Need to ramp up the voltages a bit more and I can probably be stable at 4GHz.
Update 1: Turns out 4GHz isn't happening. I can't get into windows even with the CPU at 1.57v, and my memory is total trash. I can't get past 215MHz on it. I need LED ram that also comes in 2x1GB sticks, and I hear the ballistix line has defect problems.
Update 2: New fan. new temps are 45C idle and 52C load while overclocked 1:1 to 3.0Ghz, 1.38v (stock)
http://host.atomicfire.net/files/1/watercooling/01.jpg
http://host.atomicfire.net/files/1/watercooling/02.jpg
http://host.atomicfire.net/files/1/watercooling/03.jpg
http://host.atomicfire.net/files/1/watercooling/04.jpg
http://host.atomicfire.net/files/1/watercooling/05.jpg
http://host.atomicfire.net/files/1/watercooling/06.jpg
http://host.atomicfire.net/files/1/watercooling/07.jpg
http://host.atomicfire.net/files/1/watercooling/08.jpg
http://host.atomicfire.net/files/1/watercooling/09.jpg
http://host.atomicfire.net/files/1/watercooling/10.jpg
http://host.atomicfire.net/files/1/watercooling/11.jpg
http://host.atomicfire.net/files/1/watercooling/12.jpg
http://host.atomicfire.net/files/1/watercooling/13.jpg
http://host.atomicfire.net/files/1/watercooling/14.jpg
http://host.atomicfire.net/files/1/watercooling/15.jpg
http://host.atomicfire.net/files/1/watercooling/16.jpg
http://host.atomicfire.net/files/1/watercooling/17.jpg
http://host.atomicfire.net/files/1/watercooling/18.jpg
http://host.atomicfire.net/files/1/watercooling/19.jpg
http://host.atomicfire.net/files/1/watercooling/20.jpg
http://host.atomicfire.net/files/1/watercooling/21.jpg
http://host.atomicfire.net/files/1/watercooling/22.jpg
http://host.atomicfire.net/files/1/watercooling/23.jpg
http://host.atomicfire.net/files/1/watercooling/24.jpg
http://host.atomicfire.net/files/1/watercooling/25.jpg
http://host.atomicfire.net/files/1/watercooling/26.jpg
http://host.atomicfire.net/files/1/watercooling/27.jpg
http://host.atomicfire.net/files/1/watercooling/28.jpg
http://host.atomicfire.net/files/1/watercooling/29.jpg
http://host.atomicfire.net/files/1/watercooling/30.jpg
Danger Den TDX
Danger Den D5
<3 Tygon tubing
