I recently bought a 21" Sony and am looking for some quality (within reason) cables for it as it did not come with one. Can anyone recommend a place to pick up one of these at a reasonable price?
you might also try www.sparco.com for some of the belkin cables. I got a high quality cable (supposedly for 17" and larger monitors) for $21.73 when it sells directly from Belkin for $65.99
