- Apr 8, 2002
- 60
- 0
- 0
Hey gang...
Anyone recommend a QUALITY DVI switcher for PC use? I have a 2005FPW with 1680x1050 resolution which I use for my PC. I need a quality DVI so I can switch to my laptop outputting the same resolution. I've seen there are plenty of pretty reasonable solutions for under $100, but most wont work for a resolution as high as mine on the 2005FPW.
Can anyone recommend a DVI switcher for my needs that hopefully isnt $200+ like the ones Ive seen?
Or can anyone atleast recommend an expensive one they know works perfectly?
