QuakeC Help!!!!!!
syborfical
29
It?s been a few years since I have done any Quake programming.
I can?t seem to find a copy of the QuakeC and a compiler on the net that works.
I have Quakec 1.06 and a few compilers but none of them will compile a progs.dat
I have a few older compilers that are for earlier versions of the code.
Dose anyone know where I can get;
Quake C 1.09 or 1.08?
And a compiler that works ?
Thanks.
xtknight
12,974
Heh...wow...not everyday do you see questions like this. ;)
Sorry, I really don't know how to answer your question. I might be able to point you in the right direction.
I know QuArK (Quake Army Knife) has some QuakeC editor in it (not sure if compiler is bundled, maybe in Q1 pack). Also maybe these sites will be of help:
http://wiki.quakesrc.org/index.php/QuakeC%20Basics
http://www.gue-tech.org/quake/qcrm/index.html
http://www-static.cc.gatech.edu/classes.../cs4455_spring/planetquake/quakec.html
Are you sure there was ever a 1.08 or 1.09?
syborfical
29
YAY !!!!!! it works.
Most of the compilers I tired work fine.
Back in the days.. Around 1998 when I was last programming QuakeC
I had batch files and was using win98 so my progs.dat would always be in the same dir
As the Source.
Since I?m now using windows XP it just puts the progs.dat file in the root of the drive.
Now I have 4 shot guns :p in quake
and some really silly other weapons I?ve just made
Cheers
Ps any one know how to play with quake 2 3 or 4 ?
I just want to play with the programming at the moment and add extra weapons etc ?
