Quake III max 60 frames?
idNut
3,219
WTF? I know com_maxfps X sets your max frame rate and I have that set at 0 so it'll go as high as my R9700 offers but now it doesn't surpass 60 ever since I did something. I've been playing around with my refresh rate, could that be a reason?
Davegod
2,874
is your monitor refresh rate at 60hz (use monitor buttons while ingame, not what windows is set to), and vsynch on?
i think also you should have this in your config
seta r_displayrefresh "0"
you can simply try removing your config and running Q3, which will create a new one, if fps still 60 then its nothing config-wise and put yours back in.
BlueWeasel
15,944
475
Yep, vertical sync will set your framerate to match the refresh rate of your monitor. Disable Vsync to max the framerate independently of the monitor.
