- Oct 23, 2000
- 9,200
- 765
- 126
I picked up a Quadro P4000 from a retired engineering machine yesterday and thought it would be a nice upgrade to my main PC that has been running a GTX 1060 3GB, since the Quadro is roughly equivalent to the 1060 in most gaming benchmarks, and quite a bit better in computing benchmarks. I plugged the Quadro into the second 16X slot on my motherboard and Windows immediately detected and activated the card without any driver changes or updates. I've read a lot of reports online saying not to install the Quadro and GTX drivers at the same time, so I haven't tried that yet.
BOINC and GPU-Z also appear to register the new card properly and BOINC started running two SRBase tasks simultaneously, saying that one is running on Device 0 (the 1060) and another on Device 1 (the P4000). However, GPU-Z says that the P4000 is being utilized at nearly 100% and the 1060 is not being used at all, sitting around 3-5% utilization.
And in BOINC, the two SRBase tasks are getting EXACLTY the same progress/run times, so it does appear that both are running on the Quadro. Based on those run-times, running two tasks on the Quadro is a pretty good improvement over what the 1060 was doing before, but it's nowhere near the double (or more) increase that I was hoping to get by running two separate cards.
Any suggestions how to get both cards working together, or should I just pull the 1060 and only run the Quadro since it has a lot more RAM (8GB vs 3GB), faster RAM (243.3 GB/s vs 192.2 GB/s), a lot more CUDA cores (1792 vs 1152), better fill rate (165.8 GTexels/s vs 120.5 GTexels/s) and better Floating Point performance (5,304 gflops vs 3,935 gflops)?
I know that the P4000 is not a massive powerhouse compared to new cards, but it's available and free, so I'd really like to make use of both cards if possible.
Sadly, my second PC (kids' computer) doesn't have PCIe power connectors or I'd just move the 1060 over there to replace the Quadro K2200's that they have been using to play Minecraft and I have been using to run Minecraft@home...
