Quad-shield and power lines?
drunkgamer
50
I've read quite a few times that one should not run cat5/6 parallel to power lines if not at least 1 foot apart.
How does this apply to RG6 that will be carrying in my cable internet from the street drop-off box?
The previous owner never had the house wired with conduit from the street so I had to call Time Warner and have a 3rd party come out, dig up the lawn, etc. and I had them drop it near the outside wall of my garage.
I'm going to pull it inside via some conduit and a jbox (they won't do inside-structure wiring and I didn't want this run along my outside wall).
Thing is, I need to take this to the electrical panel as I'm told they installer can't set it up if it's not grounded at the panel for some reason.
Do I still need to follow the same general conditions as cat5/6 even though it's quad-shielded cable? I know shielding is meant to help, but it's not an absolute protector.
If I run it on the other side of a stud/joist, does it still need to be a foot apart?
The real issue is getting to the panel. You can see many electrical conduits but I do see bare cable (the bare bundle appears to be phone) on the other side of the joist.
I was going to run it up this wall and across the top of the garage but there are some electrical conduit near. Also, it seems not smart to go over a jbox?
Thanks for any advice or guidance...
bobdole369
4,504
Cable internet and cable TV (digital) are far less susceptible to interference than UTP. The signal in cable is an unbalanced one, and generally at a much greater signal strength than the balanced differential signal in ethernet. You should be fine a few inches from power.
drunkgamer
50
Thanks for info. I feel better now as its going to be a lot more work to try and avoid them in the garage.
Two other Qs spring to mind:
1) What would be the symptoms of electrical interference on RG6 carrying source cable/internet data? How could I tell or measure?
2) I know most electrical is put in metal conduit to keep it from getting cut and you injured. If I run this in conduit to keep main feed protected, is metal ok or does it need to be plastic pvc conduit?
Thanks
14,092
That looks like it's all BX power runs too, not often you see that for residential but you're in luck as that will act somewhat as a shield too. You should be fine.
