Quad Monitor Output - simply 2x PCI-E cards with Dual Head each or need SLI/CF?
Syndicate
1,798
Hey guys,
I'm working on setting up a system with quad monitor output (4x DVI).
If I use an NVIDIA 650i mobo I get 2x PCI-E slots (for SLI)
Can I just plug in two 7300LEs with dual DVI outputs each and run 4 monitors or do I have to run in SLI with 2x cards that support SLI?
Also is there any issues in doing this via Vista versus XP?
Thanks!
vhx
1,151
You just need 2 PCI-E slots and 2 PCI-E cards. You don't need Crossfire or SLI to enable quad monitor support.
You would need to disable SLI anyway to get 4 monitors; only 1 monitor works with SLI enabled.
tatteredpotato
3,934
You can even go 4x PCI cards, Windows just detects multiple display adapters and lets you configure accordingly.
