Originally posted by: PremiumG
At full load my Quad core temps are around:
63C
68C
67C
60C
Should there be that much variance?? My heatsink, Arctic Cooler 7 Pro, is on correctly. I double checked the pins in the back of the motherboard. Thermal compound was applied as well.....
7C seems like a lot to me....
I recently purchased the hardware necessary to build 5 identical Q6600 G0 systems, so I had the luxury of testing out a few prevaling theories during the builds over holidays.
Like a lot of the advice you read in this thread, I walked into my builds expecting to accept anything upwards to 6-8°C temperature delta between my cores when fully loaded.
Sure enough my fourth system had a CPU which when clocked to 3.3GHz (9x367) there was a temp delta of 8°C between the cores. Sigh.
All I did was pull the HSF (Tuniq120), cleaned off the thermal grease (AS5) both the HSF and the IHS, reapplied the AS5 and reattached my HSF.
Powered-up and back into prime95 small FFT. Temp delta dropped to a mere 2°C.
Now obviously my temp delta was created by either a poor application of my thermal grease (too much, too little, entrained air pockets, etc) or the HSF wasn't tightened down uniformily (got to torque it down evenly).
Not everyone is limited by this one culprit. Temp delta can be poor contact for a number of reasons, and if it is poor contact between the IHS and the chips themselves then there is very little you can do.
But the message here is do not simply "accept" it because enough people drill it into your head that it is something you must live with. (unless it really doesn't bother you)
Go ahead and play around with the HSF and the thermal grease, and don't be too surprised if seemingly nothing more than just "redoing it" makes a world of difference as it did in my case.
