Q's: How big of a solar panel would I need to power 2 120 mm fans and where to purchase such a panel?
Zim Hosein
Super Moderator | Elite Member
65,307
403
So, as the thread title states, I would like to know how big of a solar panel I would need to power 2 120 mm fans and where would I purchase one? Thanks in advance! :beer:
Rubycon
Madame President
Aug 10, 2005
17,768
485
What are the fan specs? Typically amperes @12V. A half amp at 12V needs 6W of power to run so two would mean you need 12W. A 15W battery charger type panel would work fine. It will be more expensive if you need it permanently mounted outdoors as it has to be protected against the elements, etc.
Zim Hosein
65,307
403
Figures I'd be unprepared for your questions Rubycon! :eek:
Basically I want to use 2 Antec computer case fans powered via a solar panel for indoor use only. Make any sense?
Rubycon
Madame President
Aug 10, 2005
17,768
485
I would presume you either have a skylight or want the panels on your roof. Lighting indoors is not going to make any solar panel put out sufficient power to turn a fan. (unless you have some powerful plant growing bulbs for "high times".) And that's about all I have to say about that! :laugh:
A 10-15W battery charger type panel should suffice for < $100.00. If the fans need to run 24/7 you will need a larger panel to cover the draw plus battery charge rate and sufficient capacity to run the fans at night and on cloudy days where output is less than nominal.
You know it wasn't going to be that easy, eh? ;)
Tiamat
14,068
Not going to be easy. There are many things that alter the efficiency of solar cells. Concentrators, quantum dots, thin-film laminates, etc. How big depends on how much money you have and if there is a manufacturer/supplier.
For indoors use, you probably won't find any solutions for your needs.
A good estimate is the solar panel that is going on the new Toyota prius (in terms of what you can buy immediately today).
I could be wrong, but I think it outputs 50 Watts total. 2x 120mm fans are probably 5 Watts.
JasonCoder
1,893
Originally posted by: 91TTZ
Correct answer: spend the money on a hooker
Yeah but the ho is a one shot (so to speak) deal, whereas this setup keeps on giving, and the no disease thing is nice too...
Zim Hosein
65,307
403
1. I was hoping that the indoor lighting would be enough! :(
2. Figures Rubycon! :eek:
Feel free to lock this thread up since my idea won't work! :(
Tiamat
14,068
Yeah, unfortunately, solar cells (commercially available ones) do not absorb really well for indoor lighting. Also, when you have an array of them, blocking even a small fraction of the array will cut the power output dramatically.
SunSamurai
3,914
HA.
Or you could just turn the light off for 5x the power savings.
arcenite
10,660
7
:confused:
iGas
6,240
Depends on the fan motor, bearing designs, and CFM out put.
A 12V 120mm fan total load drawn can be less than 1W to several Watts. Then calculate the quality/efficiency of the solar panel * the Watts input that you requires. And, make sure to check the solar panel energy rating for full/direct sun to over cast.
iGas
6,240
That said, one of this, or this one should do just fine pending weather condition.
[add]
Oops, almost forgot about Fresnel. Add a big ass Fresnel lens in front of the solar panel ++ mirrors and that should increase the out put of the solar panels.
Rubycon
Madame President
Aug 10, 2005
17,768
485
[add]
Second one is ideal.
RE: Fresnels...
Yes it's true that you can increase the insolation over a given surface area which will increase the output of the cells however they will heat up...way up! It's easy to crack the cell or protective glass. A fresnel from a projection TV set can destroy a panel instantly if placed too close to the waist. Additionally if you don't have a tracking mount and the beam shifts to your roof it could cause a fire! :Q
13,602
Zim Hosein
Off Topic Moderator
:boggle;
I found that odd too. Or is it that mods can't lock their own threads? lol.
For the panels suppose if you put them in a window that gets sun, that might work?
I would love to go solar and have some on my roof. Just don't know what kind of effect the weight of snow would have on them, and I'd need a mechanism to clear the snow or they'd be useless.
BoomerD
65,984
14,380
It'd be too easy to buy a wall-wart type of power supply to run the fans? (quite a bit cheaper in initial purchase price for sure)
Zim Hosein
65,307
403
Zim Hosein
Off Topic Moderator
:boggle;
He dropped his bottle of locktite in his beer. :laugh:
:laugh:
Seriously though, I don't lock threads that I created on principle.
randay
11,018
216
it would be more efficient to turn off the lights and use a regular power supply.
Feb 19, 2001
20,155
23
what kind of efficiency do you expect?
what kind of solar panel?
- Triple junction GaAs?
- Monocrystalline Si?
- Poly Si?
- Amorphous Si?
- CIGS?
- CdTe?
I'd say you can expect 10% and above for most solutions.
So if each 120mm fan uses about... 12v x 0.5A = 6W of power. 12W total. Assuming 10% cell efficiency and 1000 W/m^2 solar irradiance, you need 0.12 m^2 of a solar panel. This is like BARE minimum though. You're assuming MAX solar irradiance which means direct sunlight with no clouds at all.. I'd go with double the size at least.
Sea Moose
6,933
7
It can be done
This is a basic block diagram of how you would have to wire it up
Solar panel ---> Solar panel regulator ---> Battery ---> Fan
You mount the solar panel and run it into the regulator which feeds the battery. you wire the fan off the battery. The regulator basicly makes sure the batt is never overcharged and helps extend battery life.
If you have a 6watt fan get a 15watt panel.
always make sure you panel is larger than the load.
