Hi all!
I have an AMD Athlon(tm) XP1600 using a QDI's k7v8366 kudo z7 running on WIN XP.
The other day all the sudden I couldn't get into the OS! I de-mount the drive and save all my data and then I tried to install the oS from the very beggining. Everything was going ok untill I was asked to reboot the PC. The configuration was to search for CD drive first then for HDD. I pressed nothing and the system booted from the CD once more! I changed the configuration to 1st booting device HDD, 2nd CD but the same happened again.
It seems to me that I have a severe problem with my BIOS. I don't know what, that's why I ask your help.
All remarks or instructions are welcomed at this point.
Thank you,
D.
Thank you,
D.
