Whats up guys?
This is my first post here...I hope you guys can help me...
Ok, so I have my pc running for like 6 months now, it was OC to 3.6ghz and 4 days ago I read some and learned I can do better so I played with the voltage (FSB, DDR3, CPU) and got it to run at 3.8ghz and the memory at 1800mhz 9-9-9-24 (default). My problem is that I tried running Futuremark Vantage (or something like that) and it run for a few minutes then froze, did it again and it froze again...after the second restart the ATI driver was damaged and I had to reinstall it. then I started getting BSOD...after few minutes running Vista Ultimate 32bit I suddenly got BSOD, I changed my OC back to 3.6ghz and the DDR3 to around 1600mhz and after 15 or 20 minutes (could be more than that) I got BSOD again...Can anyone please tell me what could be the problem?
I didn't OC the GPU at all and my voltage are under the limits (DDR3 1.7v, CPU 1.3500v, FSB 1.3v) I realy don't know what could be the problem...I'm afraid my HD4890 was damaged during the benchmark I tried to run...Is it possible??
Any help would be great!!
Also, If someone can tell me what I did wrong it would be great. I tried to run Prime95 and 2 cores fails, the other 2 kept running until I stopped the test. My CPU never got hotter then 68c...
Thanks a lot people!!
