Hi Larry..sorry i didn't get back to you earlier..it's been a heck of a day that involved, i kid you not..4 computers, but it's done and the 9450 quad is up and running on an abit ip-35 pro. it was an easy build..once i got the right bios (beta 16 version 9 or something like that. very latest available from abit today.) beta 16 version 4 worked as well, but i decided to go for the latest. the cpu shows 4 cores etc in cpu-z and task manage so all's working..but the description on boot simply says genuine intel processor but it came up at the right speed. unfortunately, one of the biggest things i wanted to check was the temperatures on the cores, but they are all out of whack..i'm quite sure the quad is not running at 212C
TAT doesn't read it, core temp does but same as the bios..about 212C. system temps appear fine. core voltage is i believe 12.325 in bios, 12.30 in cpu-z. wish i could get the real temps
hope you can see this picture ok and sorry about the long link here. i'm not very well versed in capturing and modding images
<a href="
http://s200.photobucket.com/al...w¤t=9450cpuz.jpg" target="_blank"><img src="
http://i200.photobucket.com/al...3/tenax66/9450cpuz.jpg" border="0" alt="9450cpuzfeb1008"></a>
i'm very disappointed i couldn't get it to boot with the ds4..the bioses have supposedly been quad capable for about 4 versions. but, no dice...and no enthusiast forum like abit it..if not for them, i probably would have had no luck with the abit
ps, larry..it's an ES...interesting thing is if you look at the datasheet, not a lot has been done with it, it would appear to my eyes...the one severe errata was it appears something to do with the QX9650, not the lower 9000s. tomorrow, plan to give it some push and see what it'll do
