Originally posted by: Gillbot
You try a couple remounts? Not sure how well the TDX handles the quads.
Originally posted by: NinjaJedi
I think I made a boo boo. I have the in tube on my block on the wrong side I think. the tube directly over the cpu is pulling the water out and not pushing it in. will this effect temps?
Originally posted by: aigomorla
can you put the processor @ load with a load program like OCCT and then give us the loaded core temps?
Meep? okey i need to see a picture of this...
ok I ran prime small FFts for about an hour or so. on cores 0 & 3 high was 48c on 1 & 2 it was 45c. seemed to be 2-3 degrees cooler on cores 1 & 2. ambiant is 22-23c using coretemp 96.1 for temps
those are great temps.
your not breaking 50c.
Start overclocking now and see how high she will go.
Originally posted by: WoodButcher
Agreed, your temps at load are fine. The sweet spot for my quad is 3.2, temps, voltage, speedstep is on and all the other crap but everybody's happy. That's 9x 360, memory @1:1. 3.4 the volts go up a little for stability, 3.6 fails prime generally within the hour, and I have booted and run CPUz at 3.8 but prime fails instantly. You can play with multipliers but for me 3.2 works best for quiet and fast.
Mine is a MATX board and I know his may hinder the OC but many others have had similar results on better boards with our chip, good luck and keep us posted!
Yep, normal. No bluescreens, no fanfare, just a simple "I ain't doin it" and your done.
+1
What motherboard are you using? do you have active cooling on the N + SB?,, yes? NB up a little, SB too, watch you MB temps, loosen the memory timings to get the highest CPU oc then tighten the memory and try to back down volts. Read through Graysky's guide again, I don't remember half of it.
