Originally posted by: Shmee
hmm, mine is at 3 with 1.38 v. I guess I dont even need that much, though i may in the future to get it higher. anyways, my VID is 1.25
that is overkill for sure, you could probably do it at stock.
Originally posted by: clarkey01
Hey
What I need to know from you is are there any options here that I should turn off ? My old P5B had alot fewer options. Any of these will stunt my Overclock?
Bios 1
Here is my current settings
Bios 2
Note : I can only enter 4 numbers into the voltage field, I can not put any "." so 1.257 is out.
Bios 3
Originally posted by: gplracer
Mine was at stock/auto for 3ghz which was 1.28v. I use 1.32 for 3.3ghz.
Hey
Bios 1
Hey
Bios 1
Make sure FSB to Northbridge Strap is running the memory:FSB at 1:1 ratio (i.e FSB 266 = DDR2 533). Otherwise you could limit your cpu overclock. The other options I would leave at Auto for now. Use CPU-Z Memory Tab and check FSBRAM = 1:1
Set CPU voltage to 1.40V
Set FSB Termination Voltage to Auto
Set DRAM Voltage to +0.2
Set NB Voltage to Auto
Leave the rest at Auto
CPU Spread Spectrum - Disabled
PCIe Spread Specturm - Disabled
Disable any other energy saving features such as EIST, C1E state, MAX CPUID to 3, etc.
Set NB/motherboard performance to NORMAL instead of Enhanced or Turbo or whatever.
Now relax memory timings to 5-5-5-15.
Now raise your FSB to 378. That's your 3.4ghz overclock. FSB to 400 gets you DDR2 800 and 3.6ghz. Run Orthos or Prime95 for 8 hours. If it's stable try lowering the CPU voltage to 1.39, 1.38, 1.37, etc. until you reach your stability with lowest voltage. Monitor your temperatures in CoreTemp and voltage in CPU-Z.
If 378 FSB doesn't work, increase FSB voltage by +0.1
If that doesn't work, increase FSB voltage by +0.1 and NB voltage by +0.1
If that doesn't work, try bumping each by +0.2 (shouldn't have to!)
Once stabilized, set DDR timings at 4-4-4-15 (if your ram is rated to run those). Finally download MemSet 3.4 and set Performance Level to 8 (from default of 10 or 12).
Good luck.
*The idea is to get the most stable overclock with lowest voltages across the board. For example if the system runs 3.4ghz with voltage of 1.39 but it takes 1.45 voltage to get to 3.6ghz, I would run it at 3.4ghz instead.
That's a really crappy BIOS interface. There's no way to tell what the increments, or what the default is. Remind me to avoid those mobos.Originally posted by: clarkey01
I have a P5Q which requires to manually enter in the voltage rather then from a list
I haven't read all the posts through and through.
Is he trying to "enter" a CPU voltage in the Award BIOS' "BIOS Monitor" section?
