- Jan 19, 2006
- 677
- 0
- 76
Well I have been messing around with Q6600 trying to get some OCing back into it. I had it running at 3.0ghz back in August, as my sig states, but it was getting a little hot in here so I had to set it back to stock. However, when I went to go set it back the processor now makes a strange noise. At first I thought I was going crazy, as I have never heard the processor it self make noise before, but I put my ear right up to it and it is defiantly the source.
Processor is the B3 stepping on the Q6600. Temps are about 57C under load @ 3.0ghz so it still should be in the clear heat wise. The noise itself can best be described as the sound a hard drive would make when its loading something. Honestly the noise itself isn't the issue, I just want to make sure that the processor isn't going to explode on me.
