Q6600 heat sink?
TunaBoo
3,280
Hi,
Working on my new system. Last things to buy will be the Q6600 and the P5B deluxe. I want a 3rd party air heatsink so I can do some moderate overclocking.. thinking of getting to around 2.8 GHz. 3 would be nice but not counting on it.
In any case, what kind of heatsinks can handle the output of a Q6600? Hopefully something that balances noise and cooling a little bit, but I don't expect it to be whisper quiet (will have a GF 8600 and 6 hard drives, so plenty of noise from them).
Muhadib
168
Originally posted by: TunaBoo
Hi,
Umm... the most recent review at anandtech.com will give you a good idea
http://www.anandtech.com/casecooling/showdoc.aspx?i=2967&p=5
If you are not in a rush:
Although not out yet, this is "expected" to be the best air cooling you can buy with money.
http://www.thermalright.com/a_page/main_product_ifx14.htm
P.S. If you are buying a $600+US quad core and plan to OC, I wouldn't hesitate to buy the best cooling there is.
graysky
796
Ha, that's the same setup I'm planning to buy in the near future. Wonder if you'll beat me to it, Tunaboo. I think the Thermalright ultra-120 would be a good choice since the 120 extreme and ifx14 aren't currently "launched" products anywhere I looked. Let me know what you end up doing.
TunaBoo
3,280
Well parts getting ordered in next month so can't wait too long.
Wonder if the thermalright ultra-120 fits on a P5B. Looks like it should... Never bought a heatsink that didn't have a clear fan mount.. what size of fan is meant to go with it? 120mm or something bigger?
aigomorla
21,087
3,595
YAY~ Quadcores.....
i love how these guys are so underesimated.
Anyhow, just to let you know, the TDP on these monsters can climb 200W+
A moderately overclocked Quadcore will put out around 230W which will bring a medium/high waterkit to idle temps of around 40, and load temps of near 70.
i believe stock is around 130W TDP. :p
Something you should be thinking about.
TunaBoo
3,280
Well I am not doing water on this rig.. Ultra 120 is pretty freaking big, it can't deal with a TDP of 230 watts? I have a nice 120mm fan waiting for it.. also have a 2nd fan that will be blowing outside air right into it. Like I said, not going for 3.8 GHz.. if I get 2.8 or 3 GHz I will be plenty happy, I need the multi-core aspect more than I need insane clock speed.
aigomorla
21,087
3,595
that all has to do with voltage.
If your voltage is low, and you can keep that 3ghz, from a Q6600, then sure.
But if you have a C2D right now, you'll totally understand when i say, its a different world from 1.3V -> 1.4V
graysky
796
Might wanna wait for the Ultra-120 Extreme or IPX-14 to get released. The extreme has 2 additional heat pipes (total of 6) and the yet untested IPX-14 has 8 heat pipes. I think you want the max cooling you can get w/ an o/c'ed quad core. I'm actually delaying my purchase until the IPX-14 gets reviewed. I'll point you to the review of the U-120 Extreme where it was found that this HS offered 6 degrees C cooler load temp than the standard U-120. That could be the difference between 70C and 66C.
