I have a Q6600 GO overclocked to 3.2ghz, and my temps at idle according to coretemp are ~40 degree mark and ~52 under load, so i was just wondering if they are safe temps.
My setup
Q6600 GO stepping @355*9=3.2ghz
VID is 1.275 and that is also what i am using for the overclock as it seems stable under Prime and IBT
OCZ Vanquisher cpu cooler
Asus P5Q (just the vanilla board)
4 gig OCZ ReaperHPC PC8500 running @711mhz
Asus 8800GTX
Enermax Galaxy 850 watt Power supply
I have 1 120mm intake on the front of my case, 1 90mm fan on the side blowing inwards and a 120mm exhaust fan.
Realtemp gives me temps of ~5 degrees lower than coretemp and everest ultimate so i am unsure what to believe.
Any suggestions would be appreciated
My setup
Asus 8800GTX
