Hello. I could use some help regarding OCing my pc.
my settings are
This yields 2.8GHZ or a paltry 400mhz OC. This works fine and is stable after 24 hrs of prime 95.
I have i have a stability hole from about 320-350 FSB where the machine wont post at all.
At 350 FSB i can post and begin to get into windows but hangs at the loading screen (blue scrolling bar)
When im at 350 FSB my settings/changes were
I have D-Tek Fuzion waterblock with a Thermochill 120.3PA radiator. Idle at 32c, i know this is high but i went with silent fans and my loop has two Ultras + the cpu in it.
I have RMAed TWO Asus boards thinking the board was unable to reach 1333FSB and beyond. However after two board swaps, Two sets of 2gb ram, 1 system rebuild, 2 diffrent PCI-e Video cards, its either the CPU or im doing something wrong. Please help! 2.8ghz is pathetic for this setup. I've gone through everything i can think of.
I, by no means, think I'm an expert so if you think i missed something basic, please mention it as i may have overlooked something very very simple.
my settings are
- FSB: 313
Multi: 9
VCORE: 1.2
DDRV: 2.3v
Timings: 4-4-3-10
Memory Speed: 475
All spreadspectrum disabled
All other voltages stock.
- Multi:8 and 9
VCORE: 1.3 to 1.4 (tried settings in between)
NBV: 1.45
FSB VTT: 1.45
Timing: 5-5-5-16;
Memory: 400-500mhz
DDRV: 2.3-2.325v
unlinked/linked memory at various ratios
- System:
Asus Striker Extreme: bios 1401
Q6600 G0 stepping
2x 1gb Patriot Viper DDR2 800
2x BFG 8800 Ultras
1.2kw PCP&C PSU
Everything Watercooled
