Q3TA help...shortcut icon
RgrPark
Okay i accidentally erased the Q3TA shortcut icon from my desktop... I looked for the executable file and could not find it...so i assume TA uses the same Q3 execuatable file but adds some strings on the command line, and just uses the new icon... can anyone look under their Q3TA shortcut properties and tell me what the actual command line to load up TA is? I'm tired of loading up Q3 first then picking team arena under the main menu... thanx
i have noticed that the game loads and plays much better if you also supplement the command line options with "+set com_hunkmegs 128 +set com_zonemegs 32 +set com_soundmegs 16" this is for a system with 256mb ram. adjust the settings so they stay in about these proportions until they reach 2/3-3/4 of your total system ram.
