- Nov 27, 1999
- 65,395
- 407
- 126
As the thread title asks, when using wire nuts, should one "pre-twist or not?" This is in regards to the indoor wiring, 120v AC, of a ceiling fan.
Thanks in advance! :beer;
pre-twist
Yep...then a bit of tape after the wire nut is on.
Depends on whether the wire is solid or stranded.
i replaced the ballasts in my mom's kitchen, didnt want to mess with running clean wiring so i just spiced in into the existing. i tried it both ways, twist and no twist.
no twist seemed to work better, it got a better bite on the wires and had more tension. the pre-twist just worked like a screw going into threading and would twist off easier or even fall off.
with no twist the threading in the nut would grab and seemingly self tap, then when it reached the end keep on turning until wires form twisted pair.
1-2 turns, then use the wire nut and secure w/ electrical tape right MrColin?
We dont use wire nuts or stranded in the fire alram business, it is forboten... well at least we tell folks not to ~
But if its Solid - pre-twist and twist your nuts hard! :sneaky:
I have opened many a juntion boxes to have wire nuts fall out from.
A quality wire nut of the proper size doesn't need to be " pre-twisted". When the nut is installed correctly the wires will twist when the nut is installed.
If the wires are stranded, then I don't pre-twist. If the wires are solid, then I pre-twist.
And please, for the love of God, don't use tape on a wirenut!!
Electricians tape is expensive too, just get the cheapest crap masking tape...mangle the wires together, give it a few wraps, and then be sure to nail/staple through the wires to hold them in place.
Just enough to keep the cap on if it should get jostled loose.
