- Oct 25, 1999
- 272
- 0
- 76
Howdy all,
Win98se
celeron 600
96mb ram
mb - onboard video, onboard sound, plug in modem card - not pci but pin style, usb lan adapter
1. modem disconnects without completing connection to dialup isp. Tried different isp - no go, deleted modem , shutdown, startup, redetected modem, ok in hardware diagnostic - still no connection.
Tried a different modem - same behavior, tried a lan card - not able to connect Checked diagnostics in hardware devices - ok.
Seems I get different readings for modem irq if I check it under modem properties - 3 and then in the hardware devices listing - 9.
Looked in the bios for a setting to change - none found. Looked in windows in the pci bus listing and noticed that device is listed as working properly - but under irq steering:
Settings there are
use irq steering. - checked
get irq table using ACPI BIOS - checked
get irq table using MS Specification table - checked
get irq table from protected mode PCBIOS 2.1 Call - UNchecked
get irq table from real mode PCIBIOS 2.1 call - checked
IRQ Routing Status
IRQ steering Disabled - message
IRQ Table has some errors. - message
Okay, So what do I do now?
Any help appreciated,
jazzisjazz
Win98se
celeron 600
96mb ram
Settings there are
IRQ Routing Status
jazzisjazz
