[Q] Genuine and the "un" note 2-4 battery
veltix
80
Is there any difference between genuine amd the un's one?
Battery life
Fast charging
Durability
Etc etc....
Zaap
7,162
424
so many of the so-called 'genuine' batteries sold on Amazon (certainly on ebay) and other places are fakes, that I think the main difference is it's almost worse to buy a supposed 'genuine' battery unless you're 100% sure it's legit, vs. a decent 3rd party make like Anker.
On amazon, read user reviews. So much of the OEM stuff are total fakes, almost guaranteed if they cost significantly less than usual. On ebay where there's no direct product feedback, assume ALL are fakes.
I've found no significant difference with a decent brand like Anker, and the original that came with the phone. (Note 2, 3 and 4).
The main things to look for are decent user reviews, a realistic price (if it's $6 instead of $16 for example, it's fake) and
if you need NFC, make sure it's supported.
jennywatson655
19
Thanks dear you just cleared many things because I was thinking to buy my Samsung Note 4 battery from Ebay or amazon now I will take care before placing any order. :)
