It's based on compression, higher octaine only dictates the Flash Point of the fuel. If you have 10:1 or higher compression you should go with premium.
Wether it's a Manual or an Auto is totally moot. I have an Auto with about 13.5:1 compression if I run 85 octaine (Regular Unleaded @ high altitude) I risk Pinging and Detonation.
