yes it is...
I did just that !!!
with flaskmpeg -> global project options - >audio-> enable direct stream copy...
don't forget to use the thunder.mism plugin for flask (the later versions needs it ... it offers more funcionality when ripping dvd's)
now you have your divx with ac3....
after this you must have some sort of windvd player...(if you want to hear more than 5 minutes you must have any non shareware windvd version)
then install this...
powerdivx next generation program
from
http://blacksunsoft.divx-digest.com/maine.htm
it enables some windvd driver to process that ac3 stream of any divx...
then you can hear those divx with ac3..
most of the info I got from here:
http://www.divx-digest.com
now something totally different:
powervr hercules 4500 or any other kyro 2 board rules...
