The power LED wires coming out of the case have a 3-pin female connector (the middle one is empty), and my board has a 2-pin male connector. Do I need a 3 to 2 adapter or something?
You can do what I did...get some small wire cutters, and cut right through the empty middle connector. There is no wire in there, and if you are careful to go right down the middle of it, you can "mod" that wire to fit your motherboard. I recently did that with a generic case and a Shuttle DDR motherboard and it is working just fine.
