- Nov 30, 2004
- 60,939
- 11,268
- 126
I used a script to upload images to Imgur through Nautilus. It worked pretty well, and was very convenient. I'm now using Thunar, and while I can get the script to work, I don't get the notification of success or failure like I got when using it in Nautilus.
I know nothing about Python, but looking at the script, I don't see the mechanism it used to popup notifications. Do any of you see where that happens? Here's the script I'm using...
and the whole package for anyone interested...
http://www.omgubuntu.co.uk/2010/11/quickly-upload-images-to-imgur-via-nautilus/
Code:
#!/usr/bin/python
# -*- coding: utf-8 -*-
import pycurl
import xml.dom.minidom
import StringIO
import sys
import gtk
import os
import imghdr
import locale
import gettext
try:
import pynotify
except:
print "Install pynotify. It's whoasome!"
APP="Imgur Uploader"
DIR="locale"
locale.setlocale(locale.LC_ALL, '')
gettext.bindtextdomain(APP, DIR)
gettext.textdomain(APP)
_ = gettext.gettext
##STRINGS
notimg = _("is not an image.")
notallowed = _("is not an allowed file type. Skipping.")
uploading = _("Uploading")
oneimage = _("1 image has been uploaded.")
multimages = _("images have been uploaded.")
uploadfailed = _("Unable to upload")
class Uploadr:
def __init__(self, args):
self.allowedTypes = ("jpeg", "jpg", "gif", "png", "apng", "tiff", "bmp", "pdf", "xcf")
self.images = []
self.urls = []
self.broadcasts = []
if len(args) == 1:
return
else:
for file in args:
if file == args[0] or file == "":
continue
self.type = imghdr.what(file)
if not self.type:
self.broadcasts.append(file+" "+notimg)
else:
if self.type not in self.allowedTypes:
self.broadcasts.append(self.type+" "+notallowed+file)
else:
self.images.append(file)
for file in self.images:
self.upload(file)
self.setClipBoard()
self.broadcast(self.broadcasts)
def broadcast(self, l):
try:
str = '\n'.join(l)
n = pynotify.Notification(str)
n.set_urgency(pynotify.URGENCY_LOW)
n.show()
except:
for line in l:
print line
def upload(self, file):
c = pycurl.Curl()
values = [
("key", "e85c0044b9222bc9a2813679a452f54f"),
("image", (c.FORM_FILE, file))]
buf = StringIO.StringIO()
c.setopt(c.URL, "http://imgur.com/api/upload.xml")
c.setopt(c.HTTPPOST, values)
c.setopt(c.WRITEFUNCTION, buf.write)
if c.perform():
self.broadcasts.append(uploadfailed+" "+file+".")
c.close()
return
self.result = buf.getvalue()
c.close()
doc = xml.dom.minidom.parseString(self.result)
self.urls.append(doc.getElementsByTagName("original_image")[0].childNodes[0].nodeValue)
def setClipBoard(self):
c = gtk.Clipboard()
c.set_text('\n'.join(self.urls))
c.store()
if len(self.urls) == 1:
self.broadcasts.append(oneimage)
elif len(self.urls) != 0:
self.broadcasts.append(str(len(self.urls))+" "+multimages)
if __name__ == '__main__':
uploadr = Uploadr(sys.argv)
