So I just bought a new computer. (Specs in my signature below.)
According to the Abit Guru system monitoring software my cpus idle temp is about 30 degrees, while the PWMs are IDLING on 110 degrees. This to me sounds nuts, but ok.
So I started othos to check stability and temps.. The cpu went up to about 38 degrees, but the PWM temps (the software states PWM Phase1/Phase2/Phase3/Phase4/Phase5 all with different temps) jump up to 150ish.. According to the software the shutdown temp is 125 degrees..
So what to do?
I suppose the lack of fan on my CPU is contributing to these high temps.. From what I understand PWMs are located near the cpu, aside from that I dont even know what they are..
Edit: I suppose I should mention I am currently running the CPU on stock, but I upped the RAM voltage to 2.2, it wasnt stable on the default 1.8.. Just trying to get it running stable atm.
Thoughts?
So what to do?
Thoughts?
