Putting together a USB CD burner
Timothy
103
Being a cheap dude, I'm wondering if I buy an external 5.25" USB case, slap a CD-RW drive in it, will Nero recognize it? Assuming I load the USB drives for the drive case.
In other words, are there other drivers needed besides what usually comes with the USB case?
Thanks!
bjc112
11,460
That should work.. Its the same as having it outside the case.. Just hook it up the same, No other drives should be needed...
I think that's what you were asking! :Q
Mday
18,647
Thanks!
you will have less problems if you run windows xp, but yes, it shoudl work, and nero will recognize it. assuming you have a version of nero that works with your cdrw.
