Rick James
How do my parts look so far? Anything i should do different? What else do i need besides the tubing, coolant and clamps?
MPC-CPU - i7 Nehalem/1366 Block
The MPC-CPU waterblock utilizes the multiple pin design to provide optimum performance to the Multi-Core and Multi-Die processors currently on the market and soon to be released products.
Selected options:
Fitting Size: 1/2" OD Fat Boy Fittings
Acrylic Back Plate: None
$42.95 x = $42.95
Delete item
Edit options
DD12V-D5 Pump Fixed Speed by Laing DD12V-D5 Pump Fixed Speed by Laing
The DD12V-D5 is a 12Volt pump with near silent operation. It is fixed at the #4 setting from maximum performance!
Selected options:
Fitting Size: 1/2" OD Fittings (For 1/2" ID Tubing)
$76.95 x = $76.95
Delete item
Edit options
Black Ice GTX120 Black Ice GTX120
The Black Ice® GTX120 brings true next generation PC Radiator technology to a higher level of performance. Using the new GTX platform, the GTX120 provides twice the liquid heat transfer surface area with a unique pre-cool/aftercool coolant flow configuration which increases heat transfer efficiency and internal system flow rates. High performance and quiet operation no longer need to be a compromise.
Selected options:
Fat Boy Fittings: 2 - 1/2 Inch OD Fittings
Compression Fittings: None
Color: Black
$53.95 x = $53.95
Delete item
Edit options
Fillport Reservoir Fillport Reservoir
An easy to add reservoir for a fillport system...
Selected options:
Add a Fillport: Yes - Clear
Fitting Size: 1/2" OD Fitting for 1/2" ID Tubing
Poly "T": Included
$27.65 x = $27.65
Delete item
Edit options
Selected options:
$42.95 x = $42.95
Delete item
Edit options
Selected options:
$76.95 x = $76.95
Delete item
Edit options
Selected options:
Color: Black
$53.95 x = $53.95
Delete item
Edit options
Selected options:
Poly "T": Included
$27.65 x = $27.65
Delete item
Edit options
