Originally posted by: Aluvus
Originally posted by: JEDIYoda
I have been told that for some models including the newer models Dell is still using Proprietary PSUs and parts!!
It would be best to call Dell or check the Dell website!!
Who told you so?
The newer Dells absolutely all use standard pinouts. In fact, Dell moved everything to standard BTX a few generations back; I believe they're migrating back toward ATX.
The worst incompatibility that might exist with a modern Dell would be physical fit issues.
Originally posted by: Smartazz
Alright, thanks man. I'll fix the link too.
Btw, is it a significant amount of casework that I would have to perform if I had difficulty fitting the PSU into the case?
If the issue is just the power switch, then that can be solved by removing some material with one of those "nibbler" tools, or (if you feel braver) removing the switch itself and voiding the PSU warranty. If you stumble into something really odd (I would take a good long look, and some measurements, before trying to replace the supply in one of the "slim" Dells), that could be harder to deal with.
As always, keep an eye on the fan position and how that might affect overall system ventilation.
