Putting a side window/blowhole in a case?
DyslexicHobo
706
Well I want a good case, that's fairly quiet and cool, but looks really nice too (with a side window). My case now, the Antec Sonata is really quiet and cool, but doesn't have a side window or blowhole. I was wondering how easy it would be to install a side window in my case. All I would have to do is borrow my friend's dremel, cut a hole in the side panel, then slap some lexan on it and superglue it?
And how would I go about making a blowhole in my case? Is there any guides, or is it really easy?
0roo0roo
64,795
84
possible but slow. its a steel case if i remember correctly. very hard cut.
Cheetah8799
4,508
Originally posted by: LifeStealer
Take it to a metal shop if its thick steel. You'll thank yourself.
Not when you have to write out the check for cost of labor...
I personally hate paying other people to do something I can do myself.
Sure the Dremel will take a while, but maybe the cost of labor for a shop will be the same as the cost of a new dremel. So by the time you're done, you still have yourself a tool to use again in the future!
0roo0roo
64,795
84
well your better off buying a new case if its that much work lol:) atleast then u've got two cases instead of one poorly mutilated one.
DyslexicHobo
706
Well my friend has a Dremel I can borrow, so that's not a problem. And I was thinking about buying a new case... but then I figured I'd rather try to make this one cool for practically nothing rather than spend $150 on a new cool case.
And yes... The case is steel, fairly thick steel. :/
