Put together 12 Monitor System but need help managing them
dan99t
I have put together 12 monitor system & everything seems to be working fine except I need help detecting & identifying & managing 12 monitors & get them to do what I built it for.
I have built this system for stock market trading & I will be running a main application that has 12 windows which I can detach & put each of them on a separate monitor.
I am running windows-7 ( 64 bit ) & other specs are as follows.
It is a Dell Workstation T -7500 which I upgraded with Custom Graphics cards to do necessary tasks.
Intel Xeon E5645 @ 2.4 GHz
It has 3 ATI FirePro 2460 Video cards each of them have 4 output ports & thus handles 12 monitors in total.
I2 GB DRR3 ECC RAM
12 Identical Dell ( U2412M ) 24 [COLOR=blue !important][COLOR=blue !important]inch [COLOR=blue !important]monitors[/COLOR][/COLOR][/COLOR] ( 1920X1200 )
Here is what I have now & what I would like it to do.
I have arranged 12 monitors in two rows of six each.
Windows-7 identifies 12 monitors but labels only 10 monitors with numbers 1 to 10 & shows two monitors without numbers in display property.
They are given random 12 numbers in each row & I can’t rearrange them starting with number one in bottom right corner & number 12 in Top right corner.
I am having trouble locating mouse in each monitor. I would like to point the mouse cursor in any monitor at will which I can’t do now.
I would like to detach & drag 12 windows from main application to the desired monitor.
I am willing to Buy any special multi monitor software if you guys know that can do the job.
Thanks much in advance.
