sdifox
- Sep 30, 2005
- 96,815
- 16,129
- 126
no, I meant under my skin.
err, whut.
you prefer "Hand over your arm" to "Hand over your keys" ?
err, whut.
you prefer "Hand over your arm" to "Hand over your keys" ?![]()
Interesting sidenote about locking:
If I lock my doors from the outside, it cannot be unlocked by people inside. opening the door handles won't do anything. They are literally trapped.
Wondering if anybody on here has a newer car that has the push button start where you don't need a key for the car? I remember hearing on some of the newer vehicles, there is a fob that acts as the key for the car wirelessly? So basically there is a button on the dash to start the car and as long as you have the fob in your pocket you can push the button and start the car.
I started thinking about how these work and I'm sure it has some type of proximity sensor to it so that when you're further away than say 10 feet it won't start. What happens if you leave your keys on the roof of the car and drive off though? Or perhaps you leave them sitting on the hook in the garage? The car is close enough to let you start it, but after you drive off what happens? Does the car shut off? Will it keep running? What happens when you get where you're going and turn the car off? Oh shit, I forgot the fob and now you're stuck?
Just curious if anybody knows how these work and if they are idiot proofed?
Is turning it so much more difficult than pushing a button?
My mom was talking about that with my aunts. For them, it is a huge "wow" factor, as in "wow I can start my car with a button!"
Also, even those with comfort access must insert the FOB once in a while because it will recharge the batteries.
Bluetooth is fairly simple to add. The parts are not cheap, but then when are they ever?This is incorrect. The keys on Comfort Access cars are not rechargeable and putting the key in will have no effect on the non-rechargeable battery in the keys. Honestly I wish this were not the case, but it is. I do like having Comfort Access, if only because I think it's silly to have a car where the driver has to both insert the keys AND push a start button. Between Comfort Access and bluetooth, I like being able to get in my car and use the car and my phone without taking anything out of my pockets. I wish I had both features on my E46 M3.
