i have 2x120mm fans
the rear one is what came with this Antec P160, its alittle noisy but its installed on them rubber pegs, which break if u take the fan off,(if i can find replacements ill change the fan)
and at the front ive just ripped out my vantec stealth for being everything but stealthly, and bought a Akasa Amber series 120mm fan. it moves slightly less air but is less than 20dB.
the rear fan moves more air than the front, (creating negative pressure in the case?) but at least theres a good circulation, and the front fan seems to do enough to stop masses of dust getting in through other nooks n crannies
