I'm on record saying it once and I'll say it again: It's the fuel pump.
or quite possibly the temperature sensor that will make the mixture more rich on first start.
Is there a check valve in the fuel line or fuel accumulator that may be leaking?
fuel pressure is right at 40 psi. A tad low. Also, now that the weather has warmed up into the 40's and 50's, it has been starting the past few mornings...
Temp sensor is $15 at rockauto.
just sayin'
*pokes ribs*
