Psychonauts help - Cobweb duster usage
FoBoT
how do you use the cobweb duster correctly?
after you mash Y to "grab" the cobweb, what do you do? i get stuck to it
is there another button to put it away or something?
i can't talk to anyone/put away the cob web duster because i am attached to the cobweb at that point
any help is appreciated
I'm gonna pull a Nik, I'm gonna do it.....
No, sorry,. I just can't be an asshole.
Sorry, I can't help you 🙁 but I heard it was a great game!
Ill do it.
<Nik> Wrong forum </Nik>
Ill do it.
asshole :| 😛
To use the cobweb duster, select it in your inventory and press the use button. I'm not sure which button that is since I have the PS2 version. Once you get the cobweb, go to Ford. Under the platform is a machine that will take the cobwebs and give you PSI cards.
You shouldn't be getting stuck to the cobweb. When you used the duster, it spins for a second and sucks in the web.
